Transmission coolant lines hitting the header?
Old Mar 12, 2007 | 10:08 AM
Colby 04's Avatar
Default Transmission coolant lines hitting the header?
Anybody else have this problem? Can you bend the lines to clear the header? or do you have to re-route it some way?
Old Mar 12, 2007 | 10:25 AM
KevinF56's Avatar
mine were hitting it only when i was trying to install the header on the passenger side. just took a crowbar and bent them over enough to slip the header in. they don't hit with it installed. if yours are hitting even when the header is installed, i'm sure you could bend them out of the way.
Old Mar 12, 2007 | 10:56 AM
04BlackSilverado's Avatar
You do not want the lines touching the pipes at all, you should be able to bend them a little.
Old Mar 12, 2007 | 12:13 PM
silver-mod-o's Avatar
Hunt&Fisherator
bend them or go to hoses... my -6AN hoses dont touch after a little routing and modification. the work very well so far...
Old Mar 12, 2007 | 04:02 PM
Moddoo's Avatar
I had to tweek mine a little also.
no big deal.
Old Mar 12, 2007 | 05:00 PM
budhayes3's Avatar
PT's Slowest Truck
I tweaked mine with a pry bar...just be careful not to kink the line.
Old Mar 12, 2007 | 07:49 PM
Colby 04's Avatar
I'll try bending them
zblee
63
Jun 10, 2023 01:25 PM
Oobray
Jun 13, 2022 03:38 AM
ARC
57
Feb 21, 2022 10:54 AM
chopperloco
Jul 10, 2016 10:45 PM
Nimoryan
Jul 5, 2015 03:50 PM
