Transmission Blew
Old Apr 29, 2007 | 08:48 PM
xsports33's Avatar
Default Transmission Blew
Happened while I was towing my boat back from the Lake. It never gave any signs it was going it just happened. When i was merging onto the freeway it slipped real bad going into 3rd and i lost OD (it won't engage). Third slips everytime and sometimes doesn't even engage. I was shittin' bricks because i had a few more hills to climb to get home and I had a huge boat strapped to my ***.
Trans lasted ~15K total, 4K with the Radix. You guys think it's worth trying to fix, or i was thinking a FLT Level 5? Any ideas what happened? I need to get that bad boy back on the street for boat season. Trip to Havasu is in a few weeks! Arghhhhh!!!
Old Apr 29, 2007 | 09:13 PM
FLT's Avatar
FLT
FormerVendor
A couple of things you might want to check before looking for a replacement transmission. Verify that it is full of oil and also scan the vehicle for codes. Maybe it is something simple. With what you have posted it sounds like the 3-4 clutch and the 2-4 band are probably damaged. Might want to drop the pan and see if it has a layer of black material on the bottom of the pan. If so you know what the step is. Vince
Old Apr 29, 2007 | 09:19 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
??? What is that black material on the bottom of the pan? I have that too.
Old Apr 29, 2007 | 09:23 PM
FLT's Avatar
FLT
FormerVendor
Combination of the 3-4 clutch and the band.
Old Apr 29, 2007 | 11:38 PM
xsports33's Avatar
Thanks Vince! The first time i dropped the pan, about 3 months ago there was a good amount of clutch material on the bottom of the pan. The clutches looked a little worn and warped and the 2-4 band looked a little burnt. I attributed the material to the "break in" process since it was the first time i dropped the pan. I'll check it out again and the fluid level and color. I never got a CEL, but i'll run codes anyway. If nothing works, i'll be giving you a call
Old Apr 30, 2007 | 12:08 AM
FLT's Avatar
FLT
FormerVendor
Sounds good. Let me know. Vince
Old Apr 30, 2007 | 01:09 AM
gmtechnician's Avatar
transmissions dont alway set the SES light because of a code. it has to be a certain type of code.
calsdad
Jun 14, 2023 11:07 PM
bearden86
26
Nov 15, 2015 03:58 PM
dsbodley
Nov 14, 2015 09:46 PM
nabozny21
Oct 17, 2015 07:47 PM
jscherbs
Sep 30, 2015 07:54 AM
