Which transmission for 383 LS1?
Old Aug 16, 2006 | 04:12 AM
14 Second Truck Club
Default Which transmission for 383 LS1?
I'll be putting in my 383 LS1 in about two months and want to go ahead and swap the tranny out or have it rebuilt while the motor is out. Which tranny should I get for the best price. I'm not familar at all with transmissions. I have been thinking about just getting the FLT level 3. Would that hold up good? I have had zero problems out of my 96,xxx mile stock tranny with my current set-up and all I have done is increased line pressure with my tune, billet servos for the 1-2 & 2-3 shifts, and tranny cooler.
Old Aug 16, 2006 | 07:47 AM
first of all it would be best not to increase your line pressure, second, to really know what trans you should get you really need to identify your HP/TQ goals. personally if i was going to get a built 60/65e i would get it as built as i could, go with the level 5 instead of 3.
Old Aug 16, 2006 | 08:22 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
What do you think a shift kit does? It INCREASES line pressure mechanically as opposed to the EPC silenoid with the tune. Just like everything else there is a happy medium with line pressure. I would go 80e and be done with it I have played way too much with built 65e's. With a stroker and some nitrous or boost it will make quick work of a 60/65e with traction.
Old Aug 16, 2006 | 09:44 AM
when i said increase line pressure was bad i guess i thought he would take it as doing it with the tune. it is plenty safe to do it mechanically with the shift kit but i understand it to be not so great to do it electronically with the tune and when people do do it most people just jack it as much as they can.
Old Aug 16, 2006 | 02:10 PM
1slow01Z71's Avatar
Like everything else not if done correctly. One of the first things Allen and all other tuners do is up the LP a bit to help with clutch slippage with higher hp levels. Why do you think most vehicles with tunes shift harder
Old Aug 16, 2006 | 02:21 PM
I know thats why they do it, in moderation its fine but like all things excess is not good. but we both are in agreement on this i know, but back to his original question, which transmission should he use?
Old Aug 16, 2006 | 04:51 PM
99Silver6.0's Avatar
Th400!!!!!!!!!
Old Aug 16, 2006 | 05:39 PM
Dock Rocker's Avatar
Old Aug 16, 2006 | 08:08 PM
1slow01Z71's Avatar
Originally Posted by 99Silver6.0
Th400!!!!!!!!!
And no overdrive wahoo!!!!!!!
Old Aug 16, 2006 | 08:27 PM
FLT's Avatar
FLT
FormerVendor
I have a guestion for Mr Hemi killer. What kind of rwhp do you plan on putting down? This is what we need to know first off to put you into the right transmission. If you would like to call Chuck or myself we can point you in the right direction. Many people have had bad luck with 4l60e's. If they are built correctly and not over powered I believe they will work. Give us call when you have time. Vince
