transgo and vette servos
Old Feb 15, 2009 | 01:09 AM
06ecsb4.8's Avatar
Default transgo and vette servos
i will order this my hd2 shift kit this week along with vette servos.
any ideas on how many washers to put in?
1=street 2=street/strip 3=full race
you think with this ill break traction from 1-2.(3:23 gears)
also how much TM removed with this for DD.
Old Feb 15, 2009 | 01:57 AM
02gmcbandit's Avatar
you should def have traction issues. i know i do. and all i put was the 1-2 vette servo. removed around 30 % i believe. its enough on some days it'll break traction in 3rd , but im runnin 4:11's. good luck with it im sure u'll be pleased
Old Feb 15, 2009 | 11:00 AM
oldred95's Avatar
You are talking about the accumulator washers right? I wouldn't put any in. Just the transgo alone makes it shift just about as firm and quick as a corvette servo does in a stock transmission. I haven't put a corvette servo in mine yet, I really don't think it will make it any firmer, just increase holding power.
Old Feb 15, 2009 | 12:05 PM
06ecsb4.8's Avatar
yeah.
well the reason i want to put something firmer is because
now when i shift the shift is firm(boosted line pressure)
but still grips and i feel im beign too harsh on the drivetrain.
so breaking traction would relieve some of that. and sound nice
Old Feb 15, 2009 | 12:06 PM
nighthawk08's Avatar
the vette servo makes a big difference. without a stall I would also not install any washers.
Old Feb 15, 2009 | 12:09 PM
95 bright teal's Avatar
You will want the softest setting for the shift kit, the corvette servo will firm it up enough.
I hear they will shift too hard with washers and a servo
Old Feb 15, 2009 | 12:12 PM
06ecsb4.8's Avatar
yeah. but i will be getting my tune around march, maybe lower line press. during normal driving.
the problem is i got 3.23's and i shift around 56.
and only a servo wont do the trick.
Old Feb 15, 2009 | 12:21 PM
D_reks{5.3}'s Avatar
I have 3.23s and just had my shift kit and servo done..you shouldnt put it on level 3 unless you are going to be running a converter, my tuner put mine on 3 becuz i will be having a converter in like next week. and ya it will spin them on the 1-2 shift...and you should back your line pressure all the way down with the shift kit.
Old Feb 15, 2009 | 12:27 PM
I have a 3000 stall, stock line pressure and a vette servo and about 50% tq management and it'll lay down a good patch 1-2
Old Feb 15, 2009 | 12:30 PM
06ecsb4.8's Avatar
TM. is that what kills me too.
how much should be reasonable to remove for DD?
would it be fine to remove it all in tow/haul for fun every now and then?
