Transfercase input shaft swap write-up.
Old Aug 17, 2014 | 09:10 AM
  #51
Tydriver's Avatar
Originally Posted by NuckenFuts
Just did this today and I dont want to see another snap ring again. Those suckers are a PITA
Haaa ! A good set of pliers makes them more tolerable.
Where did you get the input shaft from?? I'd really like to do this mod, since I found a NP149 case. I just need a lead on the input shaft that fits the 80e.
Old Sep 24, 2015 | 03:54 PM
  #52
Wrecker 426's Avatar
Rebuilt NP246 Transfer Case Rebuild Kits and Parts plus parts Illustration! Quality Parts. - Drivetrain
So that bearing that is supposed to be there or not in the picture it looks like nothing is there but on my 27 spline there clearly is!!!!!
guess i wont get this **** done today
Old Sep 24, 2015 | 05:03 PM
  #53
stealership for the win swapped it over for free
Old Oct 9, 2015 | 03:54 PM
  #54
alex226's Avatar
I've done the swap. Now I'm getting a horrible grinding noise in reverse and decel...
1st input shaft was wrong generation to fit into the planetary. Ordered 2nd gen input shaft with a few less teeth and it fit fine. Noticed original snap ring was too wide. Grinded it down to fit.
Transmission shop tore down both 4l80e and transfer case. Cant find anything wrong. I just got a call that there may be an "HD" version of the 246, is that the different generations/versions?
Part #: 19299088
Thats the part number for the input shaft I'm using now.
Old Feb 23, 2016 | 09:13 PM
  #55
2002_Z28_Six_Speed's Avatar
I realise this thread is old but I have a question if anyone wouldn't mind.
I have the BW4481 and planning a 4L80E swap. Can't out of the gate use the 4481. Does the input shaft swap work on the 4481 or the 4482? It looks to me that this swap is really meant for the 4wd tcases and not the awd ones.
In the event that it doesn't work out I got a 4wd tcase off a local guy for pretty cheap. It is directly compatible with a 80E but this means I lose my AWD.
Old Aug 8, 2016 | 06:38 PM
  #56
JASON 77's Avatar
Whats the correct part number for the input shaft. Lookin at puttin a 80 in my 2007 nnbs 1500 4x4
Old Aug 9, 2016 | 08:54 AM
  #57
I will see if I can dig it up. Just wanted to say if your looking for a complete set up I'll be selling my FLT 4 yank 320omd tcase flywheel and wiring if your interested. Xmsn was just rebuilt 400 miles at most on it same with converter. Got a new DD so it just sits now.
Old Aug 9, 2016 | 08:58 AM
  #58
http://http://www.drivetrain.com/par...nsferCaseSaver.
TRS-391670
I know they aren't a vendor on the site sorry if that violates the rules
Old Apr 26, 2021 | 04:26 PM
  #59
muddybowtie's Avatar
I know this write up is for a 4l60e to 4l80e transfer case. What I’m confused on is are you disassembling the 4l60e transfer case and putting a 4l80e input shaft in that one, or disassembling a 4l80e tc and putting a 4l60e input shaft in? Or is this something completely different?
Old Apr 27, 2021 | 07:53 AM
  #60
zz454Chevelle67's Avatar
I used this very same thread for info when I did mine, yes this transfer case was behind a 4L60 and is getting the input shaft replaced to match the 4L80 output shaft. I got mine on eBay for 80 bucks i think.
