Transfer Case Input Shaft Needed for 80 swap
Old Jan 5, 2014 | 07:55 PM
L8ERBRO's Avatar
Default Transfer Case Input Shaft Needed for 80 swap
Does anyone know where I can get a larger input shaft for my Transfer Case? I have an '04 SSS AWD and have parts on order for an 80 swap. It's my understanding that the input shaft will need to be changed out to accommodate the larger output of the 80e. Thanks!
Randy C.
Old Jan 5, 2014 | 08:00 PM
03sierraslt's Avatar
PM a member here time2kill
They are getting hard to come by for the AWD cases as they are a custom piece.
Old Jan 27, 2014 | 12:18 PM
ShredSled's Avatar
Doesn't PATC have one? Or maybe that was a smaller output...
Old Jan 27, 2014 | 12:24 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
PATC offers the smaller output shaft.
Old Jan 27, 2014 | 02:04 PM
Jake's Performance's Avatar
FormerVendor
I'm looking at making the transfer case inputs from an upgraded material in 32 spline. I would need to know if there is enough interest to do so and what the most popular transfer cases are. The NV 149 is one.
Old Jan 27, 2014 | 09:27 PM
ShredSled's Avatar
Np246!
Old Jan 27, 2014 | 09:52 PM
In the market for one for a SS also
Old Jan 28, 2014 | 08:25 AM
FormerVendor
I believe the 246 one is readily available.
I have a couple of the resplined outputs but I don't like to use them.
Old Nov 29, 2015 | 01:11 AM
dirtyyetsoclean's Avatar
Did you ever make the input shaft for the 149?
Old Nov 29, 2015 | 09:50 AM
The 246 can be had as a factory piece, and I agree I wouldn't want a turned down output either.
For reference for those who haven't seen the size difference.
This is a stock 65e output shaft sitting in a NVG149 input coupler that's been machined for the larger 80e output shaft.
