transfer case and drive shaft issue
Old Aug 6, 2011 | 10:41 PM
Ender06's Avatar
Default transfer case and drive shaft issue
I am currently putting a 4.3 and auto tranny out of a 99 blazer into my 95 GEO TRACKER. The transfer case on the tranny(I guess its a 4l60e) is made for a driver side front driveshaft but the Geo front axle is made for a passenger side front drive shaft. What is the easiest fix? Get a new t-case or what. One garage told me I could flip the t-case but doesn't it have vents and stuff?? Doubt that'd work. Anyone got any ideas?
Old Aug 6, 2011 | 10:43 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Swap a solid front axle in.
Old Aug 6, 2011 | 11:05 PM
Ender06's Avatar
but that would cost me ALOT...
Old Aug 6, 2011 | 11:34 PM
Or, I think there are adapters that will let you use the 4.3 with your stock transmission & t-case. Then it's all in the right place.
Old Aug 6, 2011 | 11:36 PM
Go check out suzukiconversion dot com and see how they are doing it.
Old Aug 7, 2011 | 09:27 AM
Ender06's Avatar
Ill check that out!!! Is there a possibility that I can flip the front axel??? I understand it would pull backwards if the drive shaft spins the same direction but maybe there is a chance it spins opposite direction....just pondering ideas. Trying to do this as cheap as possible but not rigging it. The stock transmission in the Geo is pretty poor condition that's why I wanna use the 4l60
Old Aug 7, 2011 | 05:05 PM
I think they have parts to use a Dana 300 (jeep) transfer case with the 700R4 (same as 4L60E). Then the front shaft is on the correct side. I think that's probably the easiest way to go.
thunder550
Oct 8, 2015 04:53 PM
MileHighSierra
Jul 22, 2015 11:19 PM
04BlackGmc
Jul 16, 2015 04:10 PM
alex226
Jul 16, 2015 10:55 AM
Gadgetized
Jul 7, 2015 04:40 PM
