Trans temp. gauge HELP!
Old Mar 4, 2007 | 05:18 PM
NubzSS's Avatar
Default Trans temp. gauge HELP!
stock trans. temp gauge just stop'd working yesterday. Can anyone tell me where the temp. sending unit taps into lines, or case?????
Old Mar 4, 2007 | 07:36 PM
FLT's Avatar
FLT
FormerVendor
The temp sender for the trans is inside the trans. It is located in the pressure manifold switch. This manifold switch is bolted to the valve body with three 10mm and two 8mm headed bolts. We do stock this part. If you need one give Chuck a call. Vince
Old Mar 5, 2007 | 03:26 PM
NubzSS's Avatar
thanks ill call him tomarow. is there an external wire that i should check first?
thunder550
Oct 8, 2015 04:53 PM
Matt C.
Aug 1, 2015 01:25 PM
dantheman1540
Jul 29, 2015 04:45 PM
Nimoryan
Jul 5, 2015 03:50 PM
