Trans temp. gauge HELP!
The temp sender for the trans is inside the trans. It is located in the pressure manifold switch. This manifold switch is bolted to the valve body with three 10mm and two 8mm headed bolts. We do stock this part. If you need one give Chuck a call. Vince
Nimoryan
Jul 5, 2015 03:50 PM
