Trans Temp Gauge
Old Nov 11, 2009 | 08:52 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by AKlowriderZ71
There was a member that posted a while back, saying he had used the pressure test port for a while, but decided to install it into the pan due to others claiming "unreliable" readings. After moving it to the pan, he said that he always showed the same temps as when it was in the pressure test port.
Hmmm, interesting. I had read here more than once that the test port wasn't as accurate, but it could be just hearsay. Out of curiousity, where's the factory sensor located, isn't it attached to the valve body, for what that's worth?
Old Nov 12, 2009 | 03:08 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Yes, it attaches to the valve body, submersed in fluid(pan).
Old Nov 12, 2009 | 04:13 AM
skolman91's Avatar
so how would it be that inaccurate if its in the pan in fluid(stock sensor for dash gauge). i would agree to get the most usefull readings i would put it inline going out to the cooler, but it cant be that much of a difference..
Old Nov 12, 2009 | 08:03 AM
I have mine installed in the pressure port - easy install - good readings
highway i run about 150 - 155 F
I just wanted to keep tabs on temp - see fluct - it doesnt.
Old Nov 12, 2009 | 09:33 PM
SilverDog's Avatar
I would buy the electrical version. If you buy an Autometer they tend to come with an adapter that works with the pressure port.
Old Nov 12, 2009 | 09:47 PM
Black'Rado's Avatar
^if u get a autometer one....the sending unit goes right in the port without a fitting
ferrellrooster
Mar 6, 2025 03:22 PM
brandon6.0
Aug 19, 2015 07:48 AM
Matt C.
Aug 1, 2015 01:25 PM
dantheman1540
Jul 29, 2015 04:45 PM
Nimoryan
Jul 5, 2015 03:50 PM
