Trans Coolers what ones work best?
Old 06-04-2009, 11:48 AM
silveradol33's Avatar
Default Trans Coolers what ones work best?
I have a 3400 PI converter in my truck with a 35in tires and I run it in the sand most of the time. Trans gets really hot really quick, whats the biggest best cooler that you guys can suggest to get for it? I already have a Derale Plate and fin style with a fan and it cant keep it under 250-275, so I dont get much time to drive it cause it gets hot so fast. I am thinking about 2 11x5x2 with a fan and mount them about my intercooler behind the grille? What do you guys have/recomend that would cool it down?
Old 06-04-2009, 11:49 AM
11.0 Moderator
SUX2BU's Avatar
Tru cool 40,000 FTW!
I just got mine yesterday for $110 with the bypass valve.
Old 06-04-2009, 11:51 AM
Wearin' da big hat
00ChevyScott's Avatar
I'm not sure 2 inline coolers are gonna be the best way to go. I think I read on performabuilts FAQ that it messes with the tranny pressures. But I 2nd the tru cool 40,000. I've got it in my truck and even on 100 degree days down here in Texas, my temps don't get above 150 even when I romp on it hard.
Old 06-04-2009, 12:40 PM
Banned
lucky77's Avatar
cant got wrong with a tru-cool 40K , , , best cooler out there
Old 06-04-2009, 12:45 PM
Resident Retard
BlackGMC's Avatar
+1 on the tru-cool, but if that guy is not big enough, there are some allison tranny coolers that are even bigger...
Sending you a PM with a link on bigger coolers.
Old 06-04-2009, 11:04 PM
PT's Slowest Truck
budhayes3's Avatar
This is correct, you don't want to drop pressure across 2 auxilary coolers...
Old 06-04-2009, 11:12 PM
SPAM HUNTER
2005 Silverado's Avatar
Are any of you running just the TruCool 40k? and not running the radiator cooler at all?
Im swapping from 5 speed to 80e, i dont want to buy a new radiator and i am going to just run a biggerish auxilary cooler as my 1 primary.
Dustin
Old 06-04-2009, 11:22 PM
Wearin' da big hat
I'm running just the 40k.
Old 06-04-2009, 11:26 PM
I dunno if that thing will do what I need man, my **** gets hot in a heartbeat and I have a Derale cooler and my factory rad one with an electric fan and it still crazy hot, maybe it will do the trick. I dont ever have issues on the road its only in the sand, thats the only problem I dont wanna do this again! If you guys say so, ill give it a try.
Old 06-04-2009, 11:27 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
I believe I was the first to run the tru-cool back in the day(4ish years ago) and I had nothing but good results from it. I ran it straight from the trans with a 4K stall, and towing, in the Texas heat the hottest I ever got it was 200*s beating on it down on the beach in the sand drags time after time with the 418. It works great, once I got it up close to 200*s Id take on an easy 1/2 mile drive and then go run another race.
Mine was without the bypass, FWIW I never had problems with the non bypass model even in northern AL with 20* temps it would still get up to 140ish*s cruising.
Quick Reply: Trans Coolers what ones work best?
