trans swap question?
Old Nov 28, 2005 | 12:24 AM
Wilde Racing's Avatar
How do I change this text
no, the AWD system is in the transfer case, just like the auto trac is in most 1500 t-cases.
Old Nov 28, 2005 | 01:58 PM
silverado_ia's Avatar
So what if I wanted AWD just swap out T-cases? is that possible without a lot work, other then the swap?
Old Nov 28, 2005 | 03:28 PM
Zick's Avatar
Originally Posted by white1
It should be fine. The gear ratios are all the same. Th e main difference between the 60, and the 65 are the 5 pinion planetaries (sp). Thats pretty much it. A lot of guys build their 60's into 65's.
Just a fyi, the 4L65E also has a hardened output shaft. I not sure if the input shaft is hardened or not though.
CammedZ71
Aug 2, 2015 01:44 AM
creekrat
Aug 2, 2015 01:27 AM
alex226
Jul 27, 2015 07:12 AM
bsn1989
Jul 16, 2015 08:20 AM
