Trans Still Shifting 2 Hard
got it back 2 the trans shop and they got 2 washers out so i only have 1 in there with the servo and it still shift hard ( barks the tires at 1/4-1/2 throttle) almost just as hard as it did with 3 washers
so i called WFM 2 see if he can tune it down a lil and he said that he dont like 2 do that 2 go back 2 the trans shop and get the other washer out
and maybe take the servo out
i dont know what 2 do
That's probably the reason right there.....get another transgo plate and drill the holes to the smaller of the two sizes. The larger is for applications with a high stall converter. Try that and leave the one washer and the servo in.
At first I had 2 washers in and it shifter really hard-barked the tires @ half throttle. I took all the washers out and it shifts a lot better. I have the holes in the seperater plate drilled the smaller size. I also have the vette servo with a longer pin. I hope this info helps you out.
There are at least three physical modifications in a shift kit affecting the 1-2 shift:
1) Number of washers
2) Size of hole in separator plate
3) Size/type of accumulator spring
I know of someone who had issues and wasn't happy until all three components were returned to stock. It is much easier to program a soft shift into a firm one than it is to tune down a harsh shift into a softer one.
Personally, I put zero (0) washers in the accumulator and it was still kind of harsh, but I was able to soften it up with programming. I've heard that if you don't have a high stall converter then you don't want any washers in there.
Don't forget, shift kits were made to be the only modifications to be installed, so if you are installing a Vette or billet intermediate servo, you are also firming up the shift, so this compounds the issue.
My recommendation for installing the Transgo + Vette or billet servo in a truck with the stock torque converter and no other programming, is to drill the smallest 1-2 hole in the accumulator plate, and put zero washers in the accumulator.
Originally Posted by 02sierraz71_5.3
If its still electronically controlled you can reduce the pressure alot with the tune, tell your tuner to use the pressure modifier table for the 1-2 it works well.
