Trans Question.
Old Feb 28, 2010 | 07:55 AM
JDC's Avatar
JDC
Default Trans Question.
What would cause this ? when coming to a corner I let off and coast around the corner and somtimes not always when I accelerate again its like its in nuteral for 1 to 2 seconds and then it goes again. Would it be in the tuning or mechanical in the trans itself ?
Old Feb 28, 2010 | 11:31 PM
FLT's Avatar
FLT
FormerVendor
Low fluid?
Old Mar 1, 2010 | 06:17 AM
JDC's Avatar
JDC
No the fluids good. full and red no burnt smell.
Old Mar 1, 2010 | 06:34 AM
ChevyTruck's Avatar
something else
My trans did not have any burnt smell to it when it popped a few months ago. Good luck trouble shooting your trans problem.
Old Mar 1, 2010 | 07:24 AM
FLT's Avatar
FLT
FormerVendor
Not sure when you serviced it last but are you sure there is a filter in there? I would also make sure that the seal in the pump for the filter is good and tight. From what you are describing it seems as you are loosing the sump. If all that is good then I guess it is possible that you have an internal issue. However why doe it only happen on turns. Weird. Vince
Old Mar 1, 2010 | 11:27 AM
budhayes3's Avatar
PT's Slowest Truck
Yea, I was thinking that maybe the filter became disconnected or partially disconnected after reading the first post, due to the fact that it happens around turns. Like you said, sounds like the filter is losing the sump.
Texas5.3_1251
Mar 5, 2016 08:10 PM
06 4.8
Sep 11, 2015 10:36 AM
11MPG
Sep 8, 2015 04:52 AM
Mark_k
Sep 7, 2015 10:15 PM
MadDMax66
Sep 5, 2015 01:27 AM
