Trans problem
Old May 11, 2008 | 11:12 AM
1BAD73's Avatar
Default Trans problem
I just swapped out my tci converter that was in my truck to put the stock converter back in. With the tci, everything worked fine other than the lockup in overdrive. After putting my stock converter back in, now my truck will not shift correctly. If I put the truck in OD it will start in first, shift to second, then will rev up instead of shifting to drive. If I start in second it will stay in second and works as it should. If I start in OD and get on it it will start in first, shift to second after hitting the rev limiter, then when it tops out in second, it will try to downshift back into first. What should i look for? Already checked fluid level. Could there be something in the valvebody? Should I change fluid and filter? Any help is appreciated.
Old May 11, 2008 | 12:04 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
What type of trans? Can you list specs of your powertrain?
Old May 11, 2008 | 12:48 PM
skeet's Avatar
man this sounds all so familar, going through this now, good luck and hope its nothing seriuos, finally got my truck back from the tranny shop, well 2 weeks later now i have lost 3/4 gears.. kicker is yesterday morning i had to get it to the paint shop, wouldnt go into 3 then OD, but after a mile and stopping at a light it shifted through all gears just fine wtf gives lol, going back to the tranny shop after it gets painted ...
6.0 4l60e in front of it with a 3200 stall... hadnt changed anything.
you may need to tune for the stock converter
Old May 11, 2008 | 07:48 PM
1BAD73's Avatar
yeah sorry,
The truck is an 00 rcsb with 5.3 and a 4l60e. The truck has 140,000 miles. I just changed the fluid and filter, it doesn't look good. The fluid is burnt, and there were small metal shavings and clutch material in the pan. The trans doesn't shift any better with new fluid and filter. I guess I will start to look for a new tranny.
Old May 11, 2008 | 08:09 PM
95ImpSS's Avatar
Originally Posted by 1BAD73
yeah sorry,
3-4 clutch pack. pull it. red eagles will serve ya better. replace filter while you're at it. i would certainly go through the trans to make sure all other parts are ok.
ferrellrooster
Mar 6, 2025 03:22 PM
Fast86z
Aug 23, 2015 12:35 AM
walledition
Jul 29, 2015 08:54 PM
grantpo
Jul 15, 2015 12:21 PM
lxcoupe
Jul 14, 2015 10:14 PM
