Trans pan UPGRADE cheap - Check it
Old Jan 26, 2011 | 04:40 PM
Dezert1500's Avatar
Default Trans pan UPGRADE cheap - Check it
I found Dorman makes aftermarket +2 quart transmission pans WITH drain plugs for 4L60e's. Makes for easy draining and adds a couple extra quarts over the stock trans pan. Cheap alternative to the pricier cast aluminum pans and looks factory. Part# 265-811
Old Jan 26, 2011 | 05:23 PM
Beatdown Z's Avatar
Laid Back
Nice Find! There only 35 bucks on Rockauto.com.
Old Jan 26, 2011 | 05:28 PM
offroadrider12's Avatar
Looks good, wonder how long it would last here in the salt though. I believe my factory pan is galvanized.
Old Jan 26, 2011 | 06:07 PM
Bumpers's Avatar
do want a drain plug
Old Jan 26, 2011 | 07:21 PM
outlawz2004's Avatar
You would have to run the trans filter designed for a deep pan wouldnt you? Mine has a drain plug but the 2 extra quarts would help out.
Old Jan 26, 2011 | 07:32 PM
ChevyTruck's Avatar
something else
Awesome find.
Old Jan 26, 2011 | 07:36 PM
charcold-bowtie's Avatar
Not necessarily, some pans have a Baffle type thing, that hold the filter up so it doesnt try to fall off the neck, thats what my aluminum hughes deep pan for the 80 has
I dont like the idea of having the plug like that either in the pan posted, altho it is a awesome price. It would make moving the trans around after removing kinda a PITA.
Old Jan 26, 2011 | 07:43 PM
Leevon's Avatar
If you drained it first then left the plug off, that problem would go away I think.
Old Jan 26, 2011 | 07:58 PM
lol, ive blown up 8 trannies and not once have I drained it first, its more mess and that isnt my problem, let the builder deal with it.
And obviously it would go away, but then u have a hole in the bottom of the trans, sliding it around on the floor
Old Jan 26, 2011 | 08:30 PM
built408's Avatar
Its hard to tell from the pic, but is it 2+ quarts over a factory deep pan? Or 2+ quarts over a factory shallow pan?
