Trans and gear calcs
Someone on here had a calculator for our trucks to calculate what RPM, MPH and so forth......that you would achieve with a certain gear and trans ratio that you are running. I would love for someone to help me find where to download this site to go to and download this calculator!!
Thanks Fellows!!!!!
James
Thanks Fellows!!!!!
James
I always just do it myself with a calculator. I came up with this a while back...
You can determine engine RPM from some calculations.
R = Engine RPM
S = Speed in MPH
G = Rear End Gear Ratio
T1 = Transmission 1st Gear Ratio
T2 = Transmission 2nd Gear Ratio
T3 = Transmission 3rd Gear Ratio
T4 = Transmission 4th Gear Ratio (OD)
V = Tire RPM at 1MPH
4L60E Ratios 4L80E Ratios
T1 = 3.059 T1 = 2.482
T2 = 1.625 T2 = 1.482
T3 = 1.000 T3 = 1.000
T4 = 0.696 T4 = 0.075
Find the RPM at a known Speed using the following:
R = V (S (G * T))
Find the Speed at a known RPM using this:
S = (((R / V) / T) / G)
Finding V is a little more complicated.
D = Tire Diameter in inches
W = Wheel Diameter in inches
C = Tire Circumference in feet
M = Tread Width in millimeters
I = Tread Width in inches
A = Sidewall Aspect Ratio
V = Axle RPM at 1MPH
L = Distance covered in one minute at 1 MPH. (88 feet)
pi = 3.14
To find the Axle RPM at 1 mile per hour use:
V = (L / C)
V = (88 / C)
Find C in several ways - if tire diameter is known, use:
C = (pi * D) / 12
C = (3.14 * D) / 12
If Diameter is unknown, use Tire Specifications:
First convert Tread Width from Millimeter to Inches
I = M / 25.3886
Then find Diameter in inches.
D = W + (2 (I (A / 100)))
D = W + (2 ((M / 25.3886) * (A / 100)))
For example, To find the engine RPM of a 3/4 ton Suburban
going 80mph in overdrive with a 4.10 rear, 4L80E and
245/75 R16 Tires, use the following:
R = (88 / ((3.14 (W + (2 ((M / 25.3886) * (A / 100)) )) /12)) * (S (G * T))
R = (88 / ((3.14 (16 + (2 ((245 / 25.3886) * (75 / 100)) )) / 12)) * (80 (4.10 * 0.75))
R = (88 / ((3.14 (16 + (2 (9.65 * .75))) / 12)) * (80 * 3.075)
R = (88 / ((3.14 (16 + (2 * 7.2375)) / 12)) * 246
R = (88 / ((3.14 (16 + 14.475)) /12)) * 246
R = (88 / ((3.14 * 30.475) /12)) * 246
R = (88 / (95.6915 / 12)) * 246
R = (88 / 7.9743) * 246
R = 11.0355 * 246
R = 2714 engine RPM (with torque converter locked)
R = Engine RPM
S = Speed in MPH
R = V (S (G * T))
pi = 3.14
V = (L / C)
V = (88 / C)
C = (pi * D) / 12
C = (3.14 * D) / 12
I = M / 25.3886
R = 11.0355 * 246
There is also a calculator on bowtieoverdrives.com
http://www.700r4.com/speedoCalc/rpmcalc.shtml
Mike
Mike
Originally Posted by closet red neck
So with the calcs I've done so far, with a 4:56 gear, 4L60E and a 285 tire(31.46) traveling @ 80mph, my rpm's will be approx. 2730???? What is ya'lls opinion??
I run 4.56:1 gears also, and with 30.4" tires (formerly 29.4") but I get away with it because of the extra overdrive. That's a lot of RPM to be spinning to just cruise. Try sustaining 2700RPM in third gear and see if you're comfortable making that much RPM on the long haul.
(I can't tell if you have the 4.56:1 gears already, hopefully this helps.)
Originally Posted by James B.
Correct.
