Trans cooler
Old Mar 19, 2008 | 09:23 AM
VHO 6.0's Avatar
Default Trans cooler
Looking to upgrade to a tb stall soon, I know my truck has got a factory trans cooler on it, should I upgrade and if so which trans cooler do most recommend? B&M, tru cool, perma cool, etc and what gvw rating?
Thanks in advance.
Old Mar 19, 2008 | 09:37 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
I have the big B&M,
From my feeble understanding you can not have too cool of a transmission, so get the largest you can.
Old Mar 19, 2008 | 09:55 AM
VHO 6.0's Avatar
Originally Posted by trever1t
I have the big B&M,
What B&M part # is it or whats the gvw on it?
Old Mar 19, 2008 | 10:16 AM
trever1t's Avatar
I don't remember....It is the larger of their 2 offerings (at least at the time, it's been a couple of years.)
Old Mar 19, 2008 | 11:35 AM
Silver-Dollar's Avatar
With the tb stall, I would probably keep the factory cooler. Also, if you are going to go through the hassle, just get a Yank 2600 or more. I suggest write down your future mods and then decide on the converter.
More than likely the issues you will have will not be from heat.
Old Mar 19, 2008 | 11:45 AM
TXsilverado's Avatar
tb stall is a good cheap stall. i was cuttin 1.88's with my stock cammed ecsb 5.3. my fuddle 3200 with an ls1 was cuttin 1.88. my new fuddle does a hair better a cooler is not a MUST with the tb since its so tight.....the biggest cooler made would be the tru-cool 40,000. its what i run and it keeps me nice and cool
Old Mar 19, 2008 | 12:00 PM
ap2002's Avatar
when I had the TB stall, I was running a B&M cooler, the 28,000gvw I believe,,, worked well
Old Mar 19, 2008 | 05:37 PM
NegraRCSB2X4auto's Avatar
tru-cool here 40000. easy install if you've already got a factory one.
Old Mar 19, 2008 | 07:27 PM
oneslammedgmc's Avatar
Where did you pick yours up at and what is the part number on it?
Old Mar 19, 2008 | 11:45 PM
moes04silverado's Avatar
i have the tru-cool 40k gvw and my tranny temps never get above 100 degrees - of course i bypassed the radiator also. that is not suggested if you run it in cold weather....my sits all winter but i picked mine up at www dot oregonperformancetransmissons dont com....
