Tranny temps
Old Oct 6, 2005 | 01:35 PM
bluecajun5.3's Avatar
11 Second Truck Club
230 is what they run these trannys stock
Old Oct 6, 2005 | 02:57 PM
GMJim's Avatar
I'm planning on putting a SS cluster in my new 06 1500 ECSB Vortec MAX with a 4L65E. Is there existing wiring for the temp gauge so I can hook it up?
Thanks
Jim
Old Oct 6, 2005 | 03:03 PM
white1's Avatar
Thanks
Jim
should work when you plug it in.
Old Oct 6, 2005 | 05:39 PM
milan's Avatar
I just put an Escalade cluster with a NuImage Stainless Steel face on. It looks awesome and the added bonus of the tranny temp gauge. How long does it take for your tranny temps to reach full operating temp? Mine takes about 20 minutes before it reads about 160 and stays there. Is that long or is that normal?
Old Oct 6, 2005 | 06:27 PM
dewmanshu's Avatar
Moderately Differentiated
Originally Posted by white1
After frying my 2nd tranny in a couple of weeks (including aquiring and installing) I finally put my temp guage in. Just wondering what is a good temp, and when to start worrying.
What matters with a trans temp gauge in my opinion is it is just a warning sign when something is F-ed up. You can run normally between 160 to 220. BUt go over that 200-220ish area and you "most likely" have problems...and I don't just mean too small of a cooler problems. You'll get a feel what's right for your truck, and just keep an eye when it goes over that...towing...add a few to it for a threshold.
Old Oct 6, 2005 | 08:20 PM
parish8's Avatar
single digit dreamer
i try and keep my temps under 200deg. i see about 160 most of the time but a couple of 1/4mile runs and i am right at 200deg.
Old Oct 7, 2005 | 04:12 PM
140 to 150 never any higher
Old Oct 7, 2005 | 04:48 PM
Snafudilligad's Avatar
140 ish during normal driving but running around in the hills on a hot day and staying in D will cause that MF'er to creep up to 200. I stay in 3 in the hills and in heat. If I hammer on it on the street in tow / haul *** mode it will creep up to 150 / 60. Thats with the stock trans cooler.
Old Oct 7, 2005 | 05:34 PM
thunder550's Avatar
High on diesel fumes
freeway cruising will get me 160 or so, city driving will put me up to 190, i usually turn on my cooler fans if it gets up much higher than that. i try to keep mine under 180.
Old Oct 7, 2005 | 07:49 PM
LBSBLOWN's Avatar
I see 145 to 176 in my Data loging but the Trans temp in the Instrument
clusters stays at 160
BTW I running a vinci 170deg stat and have my fans set to come on at
173 low speed 178 high speed.
Wolftrk99
Dec 3, 2015 08:12 PM
JordanH
Oct 3, 2015 03:59 PM
sTNT971
Sep 26, 2015 06:27 AM
kmcn47
Sep 17, 2015 01:12 AM
mayko
Sep 7, 2015 12:24 PM
