tranny fluid leaking from front of the tranny
Old Jul 29, 2013 | 01:03 PM
icedenali's Avatar
Default tranny fluid leaking from front of the tranny
hey guys, i have problem with tranny fluid leaking a lot, almost empty....it was start slipping very little at overdrive. i notice the tranny fluid leaking..could it be just front seal leaking or major problem?
Old Jul 29, 2013 | 02:50 PM
lowered907's Avatar
Front pump seal?
Old Jul 30, 2013 | 09:11 PM
Gadgetized's Avatar
Did you turn the pressure up? Sometimes it can push the seal out. If that is the problem, I would put a bead of red threadlocker around the seal to keep it in place.
Old Aug 2, 2013 | 02:45 PM
chris092183's Avatar
there's a pump mod you can do that some say will prevent front seal blow out. Basically you bore out the lube circuit to a largerdiameter. transgo has this info on the 80e hd2 instructions. Some say it is unnecessary or a bad mod. I did it on several and havent seen what is bad about it.
vmaxpro
Aug 8, 2015 10:49 PM
walledition
Jul 29, 2015 08:54 PM
Ketis
Jul 23, 2015 12:37 PM
MileHighSierra
Jul 22, 2015 11:19 PM
