tranny
Old Aug 21, 2006 | 09:28 AM
once we lined up the holes and pushed the tranny and engine back together if was a breeze
Old Aug 21, 2006 | 09:41 AM
gonzo 6.2's Avatar
Did the converter come out of the trans even an inch?
Old Aug 21, 2006 | 11:08 AM
i dont beleive so, i pulled the motor, washed down the frame, put the 6.0 in thats it.
Old Aug 21, 2006 | 07:13 PM
marooned's Avatar
If it was OK before and slipping after the engine install you had the pump gears/converter hub missaligned.The more you run it the more damage it will do/pump metal thru the trans.Its an all to frequent mistake.
Old Aug 21, 2006 | 11:26 PM
its done, gota get a rebuild o well
Old Aug 22, 2006 | 12:05 AM
gonzo 6.2's Avatar
What was the point that you figured that was the problem?
Old Aug 22, 2006 | 09:37 AM
the convertor backed out durin the swap so it blew it up. its goin for a rebuild today, lil bit stronger then stock for now.
Old Aug 22, 2006 | 09:44 AM
gonzo 6.2's Avatar
Had you moved the converter back 1/2" once it was unbolted from the flexplate you wouldnt be spending money on a R-B.Didnt it seem odd that you had to run the bell bolts in to get the engine/trans to come together?And you said when you turned the engine to put the converter bolts in it didnt seem tight when turing,it should have been noticible.
Wolftrk99
Dec 3, 2015 08:12 PM
sTNT971
Sep 26, 2015 06:27 AM
racedad70
Sep 16, 2015 01:51 PM
JordanH
Sep 12, 2015 12:02 AM
mayko
Sep 7, 2015 12:24 PM
