Tranmission shifting problem
Old Aug 13, 2008 | 09:22 PM
stevenc's Avatar
Default Tranmission shifting problem
I have been a lurker here for some time. Well this is my situation...
I have a built 4l60e in my completely stock 02 silverado with a 4.8l.
By built i mean that it has had all the usual upgrades, 9 pack, corvette servo, hardened shell, etc.
The transmission has about 25k miles on it.
Recently, I am having this issue where if I STOMP on it it sits in 1st gear, hits the rev limiter for a second or two, then shifts and when it shifts its like it shifts into 4th or something.. I get a severe bog, and a flashing CEL.
If I drive it normally it seems okay minus a slightly harsher 1-2 shift.
Any ideas?
Old Aug 13, 2008 | 09:34 PM
goldylux's Avatar
i had a similiar problem.. my (tps) wasnt working right.. changed it and it worked fine..
Old Aug 13, 2008 | 11:15 PM
stevenc's Avatar
I am now also getting a flashing CEL on hard acceleration.
Note the shift at 5500, the video doesnt show it well but it hangs there for about 2 seconds before shifting. half throttle
heres the video:
http://www.youtube.com/watch?v=ACQqM2mbsM4
Dont mind the shaking.. it shifts rough and takes me a second to steady again.
Second run: http://www.youtube.com/watch?v=-v32KEvPnrM&feature=user
Didnt shift as high.. about the same throttle position.
Old Aug 14, 2008 | 04:25 PM
performabuilt's Avatar
LS1TECH & Trucks Sponsor
Flashing cell could be engine misfire, But have you scanned for codes,
A bad TPS can cause early or late shifts
Old Aug 14, 2008 | 04:33 PM
viciousknid's Avatar
Where's the Beef?
not to hijack but i had a similar issue the other day.
I was in first. got into the throttle to about 40 and backed off. gave it some gas and it was like it was in neutral for a few seconds, let off got on, let off got on and finally shifted to 2nd and acted like nothing happend.
Haven't logged any data on it yet but does anyone have an idea. Could it be similar to the problem OP is having.
Old Aug 14, 2008 | 05:09 PM
stevenc's Avatar
Scanned for codes - Nada.
similar... except when it really acts up, goes in first up to the shift point, sits at the shift point and then upshifts/feels like its in neutral and i don't really go anywhere.. then it shifts again, and feels good.
Can a bad TPS cause a misfire?
Old Aug 15, 2008 | 02:29 PM
You can actually have a bad TPS and ENGINE MISSFIRE and not have a code
Old Aug 15, 2008 | 08:44 PM
stevenc's Avatar
My question is however, can the bad tps cause the misfire?
Old Aug 15, 2008 | 08:55 PM
ThrottleHappy7's Avatar
Though it is coming at your expenses, this is good info to know about. I know a gentleman that is starting to have trouble with his '03.
Were some of these problems remedied with the 4l65e?
Old Aug 16, 2008 | 06:03 AM
Where's the Beef?
It'll help to focus on 1 thing at a time. They mentioned mis fire because a lot of time a flashing CES light is misfire, but not always.
I say replace the TPS and see if your shifting problem goes away. Then focus on a misfire that you may or may not have.
I can't think of why it would misfire due to a bad TPS. I could see it pulling timing tho.
blownss27
Aug 14, 2020 08:27 AM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
Texas5.3_1251
Mar 5, 2016 08:10 PM
jtphelps289
Sep 29, 2015 12:00 PM
mayko
Sep 7, 2015 12:24 PM
