traction assist went out
Old Dec 18, 2005 | 12:45 AM
angelofdeath's Avatar
Default traction assist went out
anyone here has traction assist? i have an 01 ecsb sierra with the traction assist. i was driving today, only running 55-60 mph ona heavy rainy night,then all of a sudden the "traction off" sign light turned on. it usually turns off after the truck recovers after a few seconds, but it was on the whole time till i got home. turned off the engine for a few minutes then turned it back on, but the light was off. i drove it a few minutes and it never turned on again. has this ever happen to you guys? i also just got my 4/6 drop done. do guys think that would be the reason also?
Old Dec 18, 2005 | 08:08 PM
am i the only one here that has tracktion assist. anyone..........?
Old Dec 18, 2005 | 08:42 PM
Onyx 02's Avatar
I have traction assist also. I don't know what is causing your problem. Mine has 135k miles on it and no problems, suspension is also stock.
Old Dec 18, 2005 | 09:19 PM
1SlowHoe's Avatar
Destroyer of Transmissions
I don't think the computer can turn the traction control off. You have to do it manually by pushing the button and it resets to "on" whenever you start the truck again. Sounds more like a faulty switch. Maybe pull the button from the dash and see if its really dirty or loose etc...
Old Dec 19, 2005 | 01:10 AM
i'll do that. usually when the traction off light switches on when the truck does a light slip. which happens very rarely. that never happened to u guys?
Old Dec 19, 2005 | 07:49 PM
Onyx 02's Avatar
Whenever I start to lose traction, the "low traction" light comes on and you can feel it cut the fuel until you gain traction again.
Old Dec 19, 2005 | 07:59 PM
1SlowHoe's Avatar
Same thing with mine. If yours is flashing "Traction Off" without pushing the button, something is wrong. You should feel the tires spin, the "Low Traction" light come on and the truck lose power. Then the light should go out and you get your power back. "Traction Off" should not show up.
Old Dec 19, 2005 | 10:33 PM
same thing happens to me. i will feel the tires spin, the light turns on , then the light goes out to recover. having the "tracktion off" sign come up til i got home only happened once. hopefully it doesn't happen again. i'll let u guys know if it does. most likely i'll bring it to the dealership to get it fixed if it ever happens again.
Vortec350ss
Jan 12, 2016 10:36 PM
Aaron Arceneaux
Dec 21, 2015 02:54 PM
Jordan927
Nov 10, 2015 02:47 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
TAPyvehc93
Sep 14, 2015 01:22 PM
