Torsion bar cran (another1)
Old Jan 18, 2006 | 11:22 PM
5.3AlmnBlk's Avatar
Default Torsion bar cran (another1)
I searched but didnt find anything, i found out that the ride will get worst if you crank up your tb but has any 1 tryed craking the bolts like 2 turns just to get a little extra travel before hittin that bump stop (i know its not a bump stop) would you leave it resting on the bump stop or give alittle more lift befor doing so. I want to smooth out the ride but idk if cranking up 2 truns on each side will acctually make it worst or better. Also any1 cut the bumpstop a little bit just befor hitting the LCA so you can get a bit of extra travel? would leaving some space between the bump stop and the LCA smooth out the ride a bit?
Old Jan 19, 2006 | 06:42 AM
white1's Avatar
The suspension is actually designed to ride on the bump stops. I've always leveled my trucks with the torsion bars, and have never noticed a decrease in ride quality. On my current truck I did lift it about 3" with teh Ford keys, and to get enough lift for the tires, it rode like ***, but when loosened about 2-4 turns it smoothed out a good bit. I never cut my bumpstops, and dont think you need to, but you could try.
Old Jan 22, 2006 | 09:27 AM
NoChrome's Avatar
I got my tb maxed out and it rode like **** until i put on 33's now its great.
dantheman1540
Nov 1, 2015 02:59 AM
turbo6c3
Oct 5, 2015 06:11 PM
Alco
Oct 4, 2015 06:58 AM
carid
Oct 1, 2015 09:22 AM
WICK3DxGATA
Sep 24, 2015 06:56 PM
