Torque specs for brakes
Old Oct 10, 2015 | 03:34 PM
DAH32's Avatar
Default Torque specs for brakes
Does anyone use the torque specs on guidepins on the calipers?
The front is 80 lbs.
The rear is 31 lbs and I have stripped out two of the sliders. Im just tighten now with a wrench.
Does anyone not use this?
Old Oct 11, 2015 | 07:31 PM
FFDP's Avatar
I've never torqued a caliper bolt or slider bolt in my life.
Blap it with a 3/8th impact or snug tight by hand.
Old Oct 11, 2015 | 08:08 PM
Wolftrk99's Avatar
Gúdentïte!!!!!! Know theres torque spec but have seen too many back out when torqued to spec... If youre striping guide pins are the threads right and are you using a half inch or is the guide just spinning in the bracket???
Old Oct 12, 2015 | 08:02 AM
DAH32's Avatar
This is the rear brakes.
The bolts are tearing the threads out of the slider or the piece that goes up into the bracket.
Seems like after you get to wrench tight and put on a torque wrench and start to approach the spec, this is when the bolt tears the thread out.
Old Oct 12, 2015 | 08:12 AM
Wolftrk99's Avatar
Something isnt right almost soundslike the bolts are wrong thread or the slides are too soft a material
Old Oct 12, 2015 | 09:12 AM
DAH32's Avatar
The slides are the Napa brand mid grade caliper kit with their bolt.
I put the factory slide back in.
Old Oct 12, 2015 | 10:31 AM
Wolftrk99's Avatar
Have had issues with aftermarket crap.... Factory is better
dantheman1540
Nov 1, 2015 02:59 AM
ice17
Oct 7, 2015 02:39 AM
Wolftrk99
Oct 6, 2015 11:39 PM
Alco
Oct 4, 2015 06:58 AM
X_Racing1
Sep 30, 2015 01:59 AM
