Torque converter shudder
Old Dec 2, 2010 | 09:36 PM
smokeshow's Avatar
Mod with training wheels
Default Torque converter shudder
Been trying to track down the cause of some knock retard...I've been through all the common causes, lean spikes, too much timing, cheap gas, etc. My thoughts now is it might be shudder from the converter. The KR only happens right before a shift. Sometime it only pulls .5°, sometimes over 4°. Anybody else experienced/fixed a problem like this?
Old Dec 2, 2010 | 09:54 PM
MikeGyver's Avatar
Post a log or two.
Old Dec 2, 2010 | 11:01 PM
smokeshow's Avatar
Look at frames 1490 and 4870.
File Type: hpl
Old Dec 3, 2010 | 12:25 AM
Atomic's Avatar
I have a gauge for that
Hmm, thats interesing. Log torque converter slip to see what its doing. Are you locking the converter at high throttle like that?
Old Dec 3, 2010 | 08:44 AM
00Silv4.8's Avatar
Im gonna go out on a limb and maybe make an assumption like you've got pre-stages of whats up with my **** box 4L60. However I donno what exactly has caused my problems other than the Trans guy at the GM dealership up the way from my work says it needs a trans.
Old Dec 3, 2010 | 08:53 AM
mhotrodscooter's Avatar
My old 91 had a torque converter shudder. Right before it would lock up the whole truck would shake. Almost like having a bent wheel or something. I put a additive from o'reilly's & it went away.
Old Dec 3, 2010 | 09:28 AM
smokeshow's Avatar
No, converter lockup at WOT is disabled. Weird thing is the TCC dropdown menu on the PIDs list doesn't come up on my netbook where I do my scans...but it comes up no problem on my main PC where I look at the files.
I'm gonna assume thats not the reason cause its a brand new transmission. Its only got maybe 700 miles on it since the complete teardown/rebuild, and 500 of them were very easy break in miles cause of the new gears in the rear end.
Old Dec 3, 2010 | 10:33 AM
Atomic's Avatar
Delete the os file in the scanner folder, that will make it rescan for all possible parameters. Thats what HPT told me to do when the LTIT wasnt showing up.
Old Dec 6, 2010 | 05:38 PM
smokeshow's Avatar
Finally managed to get the TCC slip PID in there. Actually, I didn't do a thing, it just sort of showed up in my PID list... Anyway I made a log, and TCC slip is always at 80%, no matter what I'm doing. Idle, WOT, its all the same. So I am officially confused.
Old Dec 6, 2010 | 06:44 PM
Atomic's Avatar
Log the rpm not the percent.
