View Poll Results: WHICH TORQUE CONVERTER
YANK 9.5"
35.71%
EDGE RACING 9.5"
0%
PI VIGILANTE 9.5"
18
64.29%
Voters: 28. You may not vote on this poll
Torque Converter Poll
Old Jun 10, 2007 | 07:49 PM
RedHot04's Avatar
Default Is 2800k Stall Gonna Do It?
Precision is telling me to go w/ a 2800 Stall??? I figured at least a 3000k, I wonder if its too much
I'm told the 2800 will take better advantage of my power curve. Seems most of you guys are running 3000-3600k.
Another Mfgr. recommended a 3200k w/ my setup. I'm just not sure?
I'll just go 3000k (middle of the road) unless I am convinced otherwise, thanks guys.
- 4l60e
- 4700lb truck
- shifting @ 57-5800 rpm
- 3.73 gears
- 31" tall tires (street)
- F/I (supercharged)
- stock cam
Old Jun 10, 2007 | 07:59 PM
speedy02's Avatar
I have a TCI 3000 in now, about to go with a yank 3600.
Old Jun 10, 2007 | 08:18 PM
RedHot04's Avatar
why such a jump? and whats your setup?
Old Jun 10, 2007 | 08:23 PM
2004SSS's Avatar
i have a tcs 3000 right now and im thinking of pulling the trigger on a pi 3200 9.5 multi disc.
is there a 5 disc converter from pi?
Old Jun 10, 2007 | 08:28 PM
RedHot04's Avatar
is this what you mean?
P/I Vigilante:
9.5" lock-up 2004R, 700R4, 4L60E, 4L80E
Multi- Disc 5 plate
2400-6000 RPM's
Old Jun 10, 2007 | 08:29 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
What kind of supercharger do you have, that will make a big difference in what kind of converter you should go with. Im guessing a BD-11 is some sort of centrifugal s/c if so then I would go with a 3200 or 3600, 3600 will be good for when you put a cam in later.
Old Jun 10, 2007 | 09:02 PM
RedHot04's Avatar
centrifugal yes. Its my understanding that stall should be approx. 500-700 lower than peak torque and with most of these engines (lm7) peak seems to be @ 4000k. So now, 32-3500k seems more realistic to me. I also thought about the cam too, not sure when I'll do that though.
Thanks man. This whole f-ing process is making me I hate making a choice like this without feeling or seeing the results first.
Old Jun 10, 2007 | 10:31 PM
bluecajun5.3's Avatar
11 Second Truck Club
your shift extensions are going to suck with that low of shift points and that 3k converter.
Old Jun 10, 2007 | 10:46 PM
99LoweredSierra's Avatar
lift your shift points and go with a 3200 yank ss
Old Jun 11, 2007 | 03:25 AM
RedHot04's Avatar
Makes sense. Main reason I'm not shifting any higher is to avoid over clocking the S/C with the 11lb. pulley and stock Crank pulley. I guess it might be better to drop back to a 9 lb. pulley and move my shift points back to 6k (or rev. limit) for better overall performance? Thanks, I hadn't really considered "adjusting" my power curve in that way yet. Correct me if I'm missing the point here. it's 4am I'll check back later.
