Torque converter ???
Old Jun 17, 2008 | 05:34 PM
sv650lex's Avatar
Default Torque converter ???
Do the gen 3 motors use an ls1 style torque converter or do the torque converters out of the obs trucks work.
Thanks
Old Jun 18, 2008 | 10:38 PM
hog's Avatar
hog
The LS1 IS a GEN 3 engine.
You can install a GEn 3 4.8, 5.3, 5.7LS1, 6.0 engine into an OBS truck by using the following GM parts
If you want to install a GEn 3/4 engine in a 96-99 truck you can use the existing 4l60e by using this flexplate spacer
http://www.crateenginedepot.com/stor...2-P1343C0.aspx
and 6 of these longer bolts
http://www.crateenginedepot.com/stor...3-P1344C0.aspx
EDIT With this flexplate from a GEn 3/4 truck that used a 4l80e trans
http://www.crateenginedepot.com/stor...7-P1342C0.aspx
The 4l60e's behind the GEN 3 engines use a different input shaft than the 4l60e's behind the GEN 1(TBI), GEN 1e(Vortec 350) and GEn 2(LT1) engines so theire TC's are different as well.
peace
Hog
Old Jun 19, 2008 | 03:23 PM
sv650lex's Avatar
Good info, thanks.
99bluefirebird
Sep 17, 2015 08:05 PM
jtphelps289
Sep 11, 2015 06:37 PM
Justin87gn
Sep 10, 2015 12:06 PM
bisqikss
Sep 8, 2015 03:35 AM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
