took a ride on the roll-back...
Old Aug 24, 2008 | 06:58 PM
Superado's Avatar
11 Second Truck Club
Default took a ride on the roll-back...
leaving work yesterday...jumped into an opening in traffic in front of the store...
prolly half throttle...stumbles...loud noise
revs high...nothing...pull over into driveway next door(how ironic...a funeral home)...
no 1, 2, 3, D or R...nothing
I'm sitting in an uphill driveway so I put it in P...it holds so I'm thinking...well, it's not the diff...or the output shaft, right?
to double check I put it in D w/ the PB on and look underneath @ the DS...not spinning...
thinking pump now...
called the hook and took the roll-back ride of shame to the house...
frustrated enough to not mess with it last night not a happy camper!
this morning I check the trans fluid cold...motor not running...crank it up and re-check fluid level...way lower...pump's working
converter? input shaft?
Old Aug 24, 2008 | 07:00 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
wow that sucks!
Old Aug 24, 2008 | 07:12 PM
Superado's Avatar
to say the least...
no track time yet...no dyno runs...
JUST got the fueling issues fixed!
Old Aug 24, 2008 | 07:48 PM
artypyro's Avatar
12 Second Club
sounds like input shaft to me, mine broke on a 4-3 downshift at about 2/3 throttle. bang then free reved no movement in any gear, pulled a cooler line and cranked it over. fluid shot out . tow truck driver said maybe i should talk to his boss about some kind of frequent flyer miles ha ha. thats when you know its gettin bad.
best of luck to ya and hope it gets fixed soon.
Old Aug 24, 2008 | 07:52 PM
FLT's Avatar
FLT
FormerVendor
Input shaft or output would be my guess if the pump is working.
Old Aug 24, 2008 | 08:19 PM
Superado's Avatar
Vince-
if it was the output shaft...
wouldn't the truck be able to roll w/ the trans in P as long as the PB was disengaged?
that's what I was thinking anyway...
either usually take out anything else with it?
Old Aug 25, 2008 | 07:49 AM
FLT's Avatar
FLT
FormerVendor
It would depend on where the break in the shaft is. In most cases the break is infront of the rear carrier so it does effect the parking function. However reverse sometimes will work. This will depend on the damage to the rear planet. Is some cases it will work and others it binds. Damage with a broken output shaft is never good. Lots of broken parts. It sounds like an input shaft might be your issue here however I would not rule out the output.
Old Aug 25, 2008 | 08:12 AM
Superado's Avatar
thanks...hopefully I can get it out in a few days...
Old Aug 25, 2008 | 11:34 AM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Sucks about the trans issue. Good luck with minimal damage. Sad to say, but I'm used to component failure. Just sucks that I didn't eliminate ALL the possible causes yet.
Old Aug 25, 2008 | 12:03 PM
circusboy's Avatar
I took the same "RIDE OF SHAME" this morning at 5:30 AM
I put my new stall and tranny in this weekend and didn't get the upper cooler line to snap in all the way, but I 'm back up and running. Hope you get it resolved soon.
