tires spin in neutral
Old Sep 28, 2008 | 08:06 PM
munchman's Avatar
Default tires spin in neutral
i had my truck on a lift welding in a bung for a wideband yesterday. when i started the truck in neutral the tires started spining and the speedo was showing 30mph. is this normal?
Old Sep 28, 2008 | 08:10 PM
Mangled03gmc's Avatar
Baltimore Whore
The tires wasn't spinning 30 were they. It is normal for them to spin a lil bit but not 30 mph in N..
John
Old Sep 28, 2008 | 08:16 PM
munchman's Avatar
John
the speedo was showing 30mph but i didnt have a way to verify the speedo was correct. they were movin pretty fast
Old Sep 29, 2008 | 01:05 PM
chevrolet all the way's Avatar
does it go on the ground? if so you might wanna check ur tranny. if not i doubt they were really goin 30 so ur probably ok
Old Sep 29, 2008 | 01:38 PM
marlboroman71818's Avatar
yes it is normal. I have pulled 3 transmissions in the past 2 months now and every time it has done the same thing as yours when the new one went in.
Old Sep 29, 2008 | 02:58 PM
James B.'s Avatar
It's just the 3-4 clutches dragging. There's no torque to it. Set the parking brake if it's creating a dangerous situation.
You will also notice that in neutral if you rev the engine you'll feel some propullsion. This is caused by centrifugal force slinging the residual fluid in the 3-4 apply piston cavity to the inner circumference of the drum where it can impart some apply pressure to the clutch pack.
Go5.3tt06
Sep 12, 2015 09:29 AM
GM1697
Sep 2, 2015 08:32 AM
fastjweb
Aug 31, 2015 09:57 AM
Lostinmiself
Aug 28, 2015 06:30 PM
stock48
11
Aug 18, 2015 05:55 AM
