tire sizes
Old Nov 11, 2008 | 06:14 PM
20inch8lug's Avatar
Default tire sizes
i am looking to put bigger tires on my 1500hd stock rims. i have a small lift and 20's w/ 32's but in the winter i put on my stock wheels and want bigger tires so i can fill the wheel wells a little more. they now have 245/75/16's what size can i put on the 16's that is still safe and want get terrible wear?? what are you guys running??
Old Nov 11, 2008 | 06:49 PM
265/75/16's Wider and a little taller. You might even be able to get away with a 285/75/16 if you watch air pressure(33" tall too)
Old Nov 11, 2008 | 07:02 PM
Mort's Avatar
I think a lot of guys run 285/75/16 but the stock 6.5" rims are a little narrow for them.
Old Nov 11, 2008 | 07:16 PM
20inch8lug's Avatar
so should i run a 265 or do they make 275's what is ur suggestion? i want to go the as big as i can as long as it is safe. its currently my only ride and i have a 5 month old son so i cant have any f ups with tires.
Old Nov 11, 2008 | 07:32 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You should use LT265/75R16/E. Don't go to the 285, it is also wider, and usually a blockier tread. For winter, narrower is better. If you want really skinny but still tall tires, use LT235/85R16E.
Old Nov 12, 2008 | 11:39 AM
budhayes3's Avatar
PT's Slowest Truck
I used to run 285/75-16's on my stock aluminum wheels before I dropped my truck, it filled the wheel wells nicely and didn't rub. My buddy now has my old tires on his 03 HD2500 Crew Cab and he's happy with them also (BFG All Terrain T/A)
gbbmk
Sep 29, 2015 10:19 AM
Lamartian92
Sep 10, 2015 09:27 PM
southernsmoker
Aug 31, 2015 03:09 PM
Lamartian92
Aug 21, 2015 01:43 PM
luisalmighty09
Aug 20, 2015 11:35 PM
