Time For a New Driveline
Well, I ended up running the crewcab at the track and on the second run my driveline snapped in two. I think I was more bummed out than anything. I had a great time while it lasted but now I need a driveline. I think the three options I will be looking into are a two-piece conversion from an extra cab, a custom or find a stocker and get it high speed balanced and call it good. Anyone have any suggestions.
OK so I have called all the local driveline shops and no one can make a custom one piece due to the length. The standard ½ ton 2WD crewcab driveline is a 5" dia x .0825 wall thickness x approximately 82" long so steel is out of the question as well. GM Parts direct has the driveline (propeller shaft they call it) for $389 new and I have checked with the wrecking yards and no one has a 1 piece driveline so I can at least get it to a shop for the change over. I guess I need to bite the bullet and get an ECSB driveline and fab up a bearing crossmember.
Has anyone done the conversion, if so how did you mount the crossmember? I have searched here and GMFS for more info and only found a couple of people mentioning the conversion without much detail.
I couldn't remember the name of the shop but I did call South Bay Drive Line. Not much they could do without having the truck there and didn’t recommend another one-piece driveline if I had problems already. I don't know if that was the place you mentioned but the other shops I found were Denny’s Driveshafts and a local place called Sacramento Driveline Service. Denny’s Driveshafts seemed to be the most performance oriented shop and recommended any length over a 64" should be converted to a two-piece if I had any expectations for durability. I did manage to find a two-piece ECSB driveline and took some reference measurements so I can fab a bracket for the carrier bearing. I was hoping to get some peoples input on their own experiences with this conversion and hoe they attached the carrier bearing.
Denny's is in New York. Shipping would about kill that deal but I think if I can find a local shop to high speed balance the stock unit I'll be in alot better shape than breaking another one piece.
Well Here is the progress so far. I picked up with an ECSB driveline from the GM recyclers and took a few measurements from an ECSB to assist me along the way. I worked on this for about 6 hours today and here is what I have so far. I hope this helps someone in the future since there is not a whole lot of information out there for converting the CCSB to a 2-piece that I have been able to find.
Here is the crossmember. 1"x3" rectangle tube, 3"x3" square tube and 1/2" tube.
Here is the crossmember during a test fit in the truck .
The next step is to relocate the evap canister and take it for a test drive.
