thoughts on ford 8.8 rear end on rcsb sierra?
Any body have experience with a ford explorer 8.8 rear end on a full size rcsb truck?
With my plans on a narrowed axle and 5 lug conversion the ford explorer axle is exactly wat suits my needs.
Be ending that its about 8" narrower than a stock 10 bolt and has the correct disc brakes to run 15" wheels I want to try it. Keep in mind i am doing a ladder bar setup so leaf spring perch location is not an issue for me. Before I do so I would like to hear the pros and cons from u guys first though. Please chime in with your thoughts.
The axle I'm looking to purchase is from a 97 explorer which came with 31 spline axles. I will be building it with a spool aftermarket gear set and a diff cover. New c-clips of course ( they are a weak point) and weld the axle tubes (they are prone to spin).
I know the s10 guys do the swap but never seen it done on a full size truck. For $150 for the complete axle with brakes and everything can't go wrong! And I just found out it already has 3.73 gears so I may just leave those in there
Yea the diffs are about 3/4" difference I think. The only confusion I still have is when I search for info on the 8.8 some say it has 3/4" pinion offset others say its about 2" pinion offset.
