TH400 swap
Old Aug 6, 2008 | 12:56 AM
06chevy5.3's Avatar
Default TH400 swap
I getting parts to gether to do the swap I have already got the TCI flexplate, a hurst 3 speed shifter, and speed sensor. I still need to get the trans and converter that fit an LS1 I know I need the short tail shaft. Theres a few things Im not sure about, I read in a older post the 5 speed crossmember will work with a 1" spacer on the mount? What size dip stick to get 24" seems to be the largest ive seen from Lokar? How much does the drive shaft need to be leingthened I have the 2 piece steel shaft?
Old Aug 7, 2008 | 01:23 AM
06chevy5.3's Avatar
Anyone??????
Old Aug 10, 2008 | 05:36 PM
vanillagorilla's Avatar
Your driveshaft will need to be lengthened roughly 3" with the 4" TH400 tailshaft, but there's no way to say for sure. You need to measure your truck specifically and have one custom made. The 5spd crossmember with a 1" spacer sould be what you need. Loakar makes a LONG dipstick for the TH400, the standard one is 24" and its not long enough.
Old Aug 10, 2008 | 10:11 PM
06chevy5.3's Avatar
Thanks
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
XL7
May 5, 2022 01:48 PM
121
Jul 16, 2015 12:18 AM
ALynch
Jul 6, 2015 09:49 AM
