Th400 question
Old Jan 21, 2010 | 11:10 PM
88bluchevy's Avatar
Default Th400 question
I have a built th400 but the kickdown cable isnt hooked up. I just ordered the kickdown cable and my question is will I see any improvements. The tranny currently has a shift kit but wont chirp 2nd. Just wondering if hooking up the kickdown cable will increase line pressure somehow.
Old Jan 22, 2010 | 06:45 PM
JoeyGC5's Avatar
Not really, imo. It will be more responsive when passing, and under heavy loads. I've always removed the kickdown and just manually shifted or let the tranny upshift for me.
Old Jan 23, 2010 | 06:14 PM
busta9876's Avatar
TH400's did not have kickdown cable. They have a kickdown solenoid mounted inside the trans and an electrical connector on the side of the case.
TH350's had a kickdown cable.
Old Jan 23, 2010 | 10:25 PM
88bluchevy's Avatar
Everything was electric until we put the new motor in and we disconnected it. Ive ordered a kickdown cable kit from lokar and was just wondering if it would the performance of the tranny.
Old Jan 23, 2010 | 10:52 PM
MikeGyver's Avatar
The kick down switch is just that, no more and no less. Get an adjustable vacuum modulator. If you disconnect the vacuum line, it should shift way harder. The adjustable one lets you make it firmer than stock, but not as hard as taking the vacuum line off.
andrewlong
Nov 9, 2016 09:38 AM
ls1curt
Jan 5, 2016 11:33 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
andrewlong
Sep 8, 2015 10:25 PM
Forcefed81
Sep 8, 2015 10:02 PM
