TC not spinning on shaft what does that mean!!
Old Oct 9, 2006 | 08:36 PM
adrenalinep's Avatar
Default TC not spinning on shaft what does that mean!!
I have the converter full engaged on the shaft but it doesnt spin freely . I t gets hard and clicks Is something screwed up!!
Old Oct 9, 2006 | 08:51 PM
anyone
Old Oct 9, 2006 | 09:07 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Is the tranny still on the ground or are you trying to bolt the tranny back to the engine right now?
Is it clicking while your trying to seat it onto the tran shaft? (spin and push 3 times?)
Old Oct 9, 2006 | 09:26 PM
its on the ground right now, It is fully engaged , but on the previous ones ive done it would spin freely . Maybe I troubleshooted wrong . The truck move at all and got some codes that said torque convereter malfunction
Old Oct 9, 2006 | 09:36 PM
1SlowHoe's Avatar
I'd pull it off and check the shaft and inside the TC. See if anything looks chewed up. If it all looks good, top it off with fluid and see if it will re-seat and spin.
Is this a new TC?
Old Oct 9, 2006 | 09:46 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
He bought my new Howard converter. It should slide on the two shafts easily then you should have to spin and jiggle it a little to get the slots to seat on the tabs on the pump rotor. Shine a light in the trans and make sure the tabs on the pump rotor are still there and in good condition, you may have cracked it upon removal or trying install this new ocnverter.
Old Oct 9, 2006 | 10:05 PM
well I reinstalled the tb stall and it goes on the same way. I can turn the outer shaft by hand but the bigger one doent turn, maybe something internally
Old Oct 9, 2006 | 10:09 PM
1slow01Z71's Avatar
Shine a light into the transmission where the outer shaft goes into the transmission there should be two tabs in there opposite of each other if there isnt then ur in trouble.
Old Oct 9, 2006 | 10:10 PM
1slow01Z71's Avatar
I would bet money since niether converter will go in there and you were experience no movement when the old tc was in sounds like a broken pump
Old Oct 9, 2006 | 10:12 PM
1SlowHoe's Avatar
