TB STALL, not happy
Old May 12, 2006 | 01:38 AM
adrenalinep's Avatar
Default TB STALL, not happy
Well I just installed my tb stall and it only brake stalls to 2200rpm. I thought its supposed to go to 2600, does it need to break in or a retune please let me know
Old May 12, 2006 | 02:18 AM
TouchOfEvil04's Avatar
No, thats about right for a TB stall.It will brake stall to about 2200rpms but when you flash it off the line it should hit around 2600rpms.
Old May 12, 2006 | 03:08 AM
Cuerva's Avatar
11 Second Truck Club
That sounds about right. My Vig 3000 only brake stalls to 2500.
Old May 12, 2006 | 06:36 AM
Quik's Avatar
5 year bitches!
ppl need to realize flash and brake are two different stall points
damm noobs
Old May 12, 2006 | 08:47 AM
ap2002's Avatar
damm noobs
yup this is true...
Old May 12, 2006 | 08:50 AM
ap2002's Avatar
with my 3.42's and the TB conv. it would stall to 2550-2600 and it would flash at about the same too,
then when I installed my 4.10's it would stall to about 1900rpm!! and I was pissed... (thats when I didnt know the difference between stall and flash) but it did flash at 2500-2600rpm...
by the way a retune always helps out..
Old May 12, 2006 | 10:20 AM
TXsilverado's Avatar
sounds like everything is working right step it to the floor and watch the smoke
Old May 12, 2006 | 10:31 AM
spitfire2332's Avatar
can someone explain to me this "flash". I know what brake stall is, but not a clue what flash is.
Old May 12, 2006 | 10:38 AM
white1's Avatar
What the converter will "flash" stall to . Stop on a straight road. Release teh brake and let teh truck roll free, then hammer it, watch the Tach, and where the truck starts to move (or smoke the tires) is your flash stall. Usually its a little higher than brake stall unless you have tall gears (lower numbers)
Old May 12, 2006 | 10:40 AM
yeah, i have no clue how people can figure out flash crap. when i try this method it immediatly breaks traction and shoots to 4000 rpm.
