T-56 swap
Old 05-07-2005, 11:33 PM
hpdriven's Avatar
Default T-56 swap
I have a RCSB silvy with the 4.8 and the nv3500 5 speed tranny and i am saving for the6.0 and wanting to put a t-56 behind it but i was wondering how much trouble is the tranny swap. what kind of parts will i need? like flywheel ,driveshaft ,tranny crossmember. any advice will be great thanks guys.
Old 05-07-2005, 11:51 PM
hpdriven's Avatar
would putting an automatic behind the 6.0 be any better than the t56?
Old 05-08-2005, 01:09 AM
TURBO8's Avatar
As soon as I get my motor shipped here, and some time away from the newborn, I will let you know.
Old 05-08-2005, 01:17 AM
desTRUCKtive's Avatar
I think the only hard part about putting the automatic is getting all of the electronic stuff to work. As far and it going in it is not that hard. For a 56 you would need a flywheel, clutch and slave. Your master clutch, your crossmember should work (pretty sure that it does), shorten the drive shaft and I think that is it. Oh and a 56 of a 98 LS1
I think if you run an auto you should get a very good built one. I would do a 56 since you are already manual.
Old 05-08-2005, 10:37 PM
hpdriven's Avatar
I see you siad 98 ls1 is there a reason for that or can it be any ls1 t56? The T56 is the six speed right? thats for yalls help
Old 05-10-2005, 07:35 AM
how much power can the stock 4.8 5spd hold up to?
XL7
05-05-2022 01:48 PM
Bluecollar Hotrods
03-13-2017 05:02 PM
GrooveCityZ71
08-31-2015 12:05 PM
superchomper2003
08-26-2015 09:39 AM
iregret
07-27-2015 10:32 PM
Quick Reply: T-56 swap
