Suspension drop question...
Old Feb 18, 2009 | 12:08 AM
Sierra1320's Avatar
Default Suspension drop question...
My question is if I want to drop my truck 3/5...could I just buy a 3/4 drop kit with coils up front and shackle/hanger kit in the rear, then take the blocks out from the rear to achieve the last 1" drop? Would that work or does taking that block out make much of a difference? Thanks.
Old Feb 18, 2009 | 09:54 AM
95 bright teal's Avatar
Are you 4wd?
if not there are no blocks. you can remove the overload spring which will be close to an inch.
then you need to think about traction aids like caltracs
Old Feb 18, 2009 | 03:56 PM
Sierra1320's Avatar
Ahhh I didn't realize that the blocks only came on 4wd trucks. Correct, my truck is 2wd. My fault...guess I should've just looked underneath my truck. So taking the overload spring out with get an inch...I take it will decrease the payload a little bit. Thanks 95brightteal!
Old Feb 18, 2009 | 04:13 PM
JAVI05's Avatar
pls. stop saying that only 4wd have rear blocks. maybe in 06. but not newer. mine is 2wd with torsion bars and blocks... not trying to be a smart ****, but i had someone tell me this too and caused alot of headaches. lol...
Old Feb 18, 2009 | 04:21 PM
LoweredZ71's Avatar
Javi05 your truck is realy high for a 2wd looks to me like someone cranked the hell outta the bars and put lift blocks in. hell it is way higher than my 4x4 when it was stock.
Old Feb 19, 2009 | 12:51 AM
he has a RCSB, they did not make a VHO with a torsion setup ever, so i am safe in asking him.
now with an ECSB you have an argument.
And i always check to be sure...
Old Feb 19, 2009 | 12:52 AM
Do you plan on doing a C-notch? with much more than 4" i would recommend it, otherwise you will be hitting frame. I plan to notch mine before i pull the overload
Old Feb 19, 2009 | 06:59 AM
JAVI05's Avatar
can u believe that its stock? tell me about it i am about to do a good 3/4 drop on it and see where it sits. for some reason gm decided to lift it some to fit the 20's on there..
Old Feb 19, 2009 | 10:07 AM
BigCountryx's Avatar
I can almost guarantee the dealer cranked the bars J. that's not set at GM spec'd Z height. And yes, if you have t-bars (2wd or 4wd) and are not an SS, you have rear blocks. Coiled trucks have none.
Old Feb 19, 2009 | 10:25 AM
nighthawk08's Avatar
how did you get a 2wd truck with torsion bars and a 4.8L? thats confusing.
