Summit Big Brakes?
The Rear Portion will Work all day long as your gonna get the calipers and brackets.
However the front kit im unsure. I check from Napa/CQ and they have different part numbers For front Rotors and Calipers between an 06 sivlerado and tahoe/yukons/esky(from which that kit posted is made for)...So if you go with a 05+ Bigger caliper that kit made for a Truck... itmay not fit. IF you Get Tahoe Front calipers I dont see it being an issue..but not alot of guys have tried tahoe calipers on a Silverado
Best to buy 05+ front kit and Any suburban Rear Kit and get the Suburban rear calipers
Heres what you need.
05- up silverado front calipers, they will say " PBR" on them, they are for the larger 13'' rotors vs. the 12'' older style rotors.
You can use the rear dual piston calipers of off a suburban or tahoe/yukon, but will need the bracket from that vehicle also to mount them.
Here is a thread a member made with great info, check it out!
https://www.performancetrucks.net/fo...ighlight=qwank
Tim94gt
23
Sep 18, 2015 04:51 PM
