Started working on the rear suspension today
Old May 20, 2012 | 03:42 PM
  #51
ak2007r6's Avatar
That's looking great. Wish I had some of the fab skills you do
Old May 20, 2012 | 04:55 PM
  #52
BlackGMC's Avatar
Resident Retard
Thanks guys. I really enjoy doing stuff like this.
Old May 20, 2012 | 11:52 PM
  #53
BlackGMC's Avatar
Resident Retard
I just ordered the grade 8 bolts and some rod end adjusters, those should give me the little extra length to reach all the hole, and it will allow me to put a wrench on the tubes.
QA1 Precision Products AS12-12 - QA1 Rod End Linkage Adjusters - Overview - SummitRacing.com
Old May 21, 2012 | 08:03 PM
  #54
BlackGMC's Avatar
Resident Retard
Decided to add a little more bracing, just in case since i have no idea on how much torque is put on that piece. Everything is 3/16 steel and the tubing is 1.25 .120 wall steel, soo this probably over kill but better safe than broken...
All painted up.
also looking at the pictures, i should have angled the mounting holes at a better angle, but oh well it will work...
Old May 21, 2012 | 10:45 PM
  #55
AKlowriderZ71's Avatar
11 Second Hall Moniter
I'm glad to see you add that bracing.
Old May 21, 2012 | 10:58 PM
  #56
BlackGMC's Avatar
Resident Retard
Yeah it should go nowhere now
Old May 24, 2012 | 09:00 PM
  #57
BlackGMC's Avatar
Resident Retard
I got the brackets all done today and painted... I picked up the tubing for the actual bars. I am still waiting on another set of weld in bungs... The adjusters i bought have female RH threads and male LH threads.. Soooo i the ones i had were not correct, hopefully they should be here next week.
Here are the adjusters, they are QA1s, also they are chrome moly (however you spell it) soo these combines with the regular rod ends should be me plenty of length to run any of the adjustment holes i want....
here are the adjusters attached to the rod ends and bung.
here are the painted brackets.
Old May 24, 2012 | 10:35 PM
  #58
TXsilverado's Avatar
looks like it's guna hang pretty low.
Old May 24, 2012 | 11:10 PM
  #59
BlackGMC's Avatar
Resident Retard
Yeah the rear bracket has about 8.5 inches and the front has about 10.5 inches of clearance from the ground. I guess that is OK i will see if they snag on anything
Old May 25, 2012 | 09:55 AM
  #60
walledition's Avatar
you should make all that stuff 2 times and send it this way, i wish i knew more about suspension, where do u get the ideas?
