stall help
Originally Posted by blake2kz71
yeh if you could get traction, and yes a tranny cooler is required. get a hayden from oreilleys. Id say 2800-3000 stall would be fine.
The ends on the cooler broke off on one that I had almost a few thousand miles after new.
Originally Posted by Dirty 30
I would stay away from hayden tranny coolers.
who is a suggested manufacture then. I need to get one also when i do my converter.
Also while im here, how difficult of job is it to install the converter? I have done all mods myself up to this point, but I dont know about the converter yet....any suggestions
hows is this one from B&M
http://www.autoanything.com/coolers/65A3046A0A0.aspx
i'm running their 30k gvw cooler with a 3k stall with not one problem after 15k miles.
My vote is for 3200+. With a 3200-3400 converter that is 10.5" you will still be able to tow a little bit as long as you have a good cooler. One way to go about cooling a transmission. If you have a big converter you will mostlikely not be able to keep it cool enough with out numerous coolers. I have a rv cooler, like 21"x21" and with a loose 2800 converter and after to sprayed runs in bou t90 degree weather after driving an hour to tune i nthis weather i stayed right around 157-163 trans temp.
That B&M is a good cooler. I believe they are made by Tru-Cool, which make that plate style low pressure drop cooler for several companies. No matter which brand you choose that is the style you want to get, I would stay away from the cheap aluminum fined jobbers.
Banned
the only way you can tow with that and no worry is if you get a triple disc
i would get a fuddle triple if the guy that i deal with don't hook me up with a triple disc like he said i will be getting a fuddle 3200 like goshawk
