Which Stall Converter??
Old Nov 2, 2006 | 04:55 PM
SierraSport's Avatar
Default Which Stall Converter??
Im thinking about getting a stall for the new tranny. I was kind of kicking around the idea of putting a Yank 2600 in .. Now my question is, where is the best place to get the stall -or- If you have a better idea, I would like to here it ..
Old Nov 2, 2006 | 05:01 PM
Sport Side's Avatar
Yank is fine. Just go bigger...
Any goals? What type of usage? You race it?
Old Nov 2, 2006 | 05:08 PM
Rhino79's Avatar
9 Second Club
I wouldn't go less than 3000, but like SportSide said, what are your intentions?
Old Nov 2, 2006 | 05:14 PM
It is mainly my daily , I dont really race it much unless I get the urge to put the panties on a ricer or 5 at the weekend Races.. I believe in making it built to what you would want while it is out .. I have only seen the 2600 and 3200 stalls..
My real plans is once this motor hits 100,000 to put a fresh 4.8/5.3/6.0/LSX w/ turbo in it ..
Old Nov 2, 2006 | 05:18 PM
The reason I say 2600 is because my truck starts to pull at about 2800 rpm. everybosy I know with the 2600 says it doesnt lock in at 2600 but later then that .. I dont want my daily to drive around like my Camaro did with the 3500 stall it had ..
Old Nov 2, 2006 | 05:23 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Yanks a tight. I had a TT3000 previously and it is fine for DD, the TT2600 would work just as well for a stock cam setup but if you plan or think you might cam swap then look at the TT3000.
Old Nov 2, 2006 | 05:24 PM
What about this stall
ST2600 LS1 Stealth 2600 (300mm, 2600 stall, 1.90 STR)
I just want a lil bit more life when it shifts(it falls on its face when it shift till it hits 2800rpm), I dont plan on trying to set any records in this thing ..
Old Nov 2, 2006 | 05:28 PM
Im guessing the Truck Stall is different then F-Body stall .. I dont plan on doing anything much to this motor, I will probably have a 4l80e built in the future for the truck and throw this in one of my other rides..
Old Nov 2, 2006 | 06:07 PM
Okie5.3's Avatar
might leave ya feeling a little unsatisfied...for nothing else the shift extensions alone of a 3-3200 stall would make the looser verter worth it...IMHO
Old Nov 2, 2006 | 06:09 PM
a 1.9 str is too small. i would go with a 3000 with a 2.3 STR
