Stall choices
Old Sep 15, 2011 | 05:17 PM
  #21
grey matter 04's Avatar
13 Second Truck Club
I called Circle D today asking some questions
I found a smokin deal on 245mm 3600 c4 multi disc stall BUT was advised against it because of my towing needs
Was recommended the 258mm verison for my needs BUT the $1045 price kinda hurts
SOO
I asked about the 278mm 3200 stall if it could be tweeked some .Was told yes they could loosen it up some but couldnt say if it would stall 1-400rpm more.
I may go this route ^^^^to keep my towing capability and gain a few rpm more stall speed.WORST case i gain 200rpm more stall but i have a feeling it will stall 3400.Also stays away from a really loose stall which i really dont want in my DD
To try this i am only out a few dollars with selling my yank
Old Sep 15, 2011 | 05:38 PM
  #22
Bumpers's Avatar
Might as well.. Tell em to make it loose as possible
Old Sep 15, 2011 | 05:45 PM
  #23
Beatdown Z's Avatar
Laid Back
There's a Yank PT3200 on ebay... YANK PRO TRUCK 3200 BILLET TORQUE CONVERTER, LS1 TRUCK/ 4L60-65-70E TRANNY - eBay (item 220851861180 end time Sep-18-11 15:39:51 PDT)
Old Sep 15, 2011 | 06:13 PM
  #24
Thanks i will watch that close!
Old Sep 15, 2011 | 09:14 PM
  #25
silver-mod-o's Avatar
Hunt&Fisherator
We have that 278mm converter in a Cammed 6L ext cab truck with some spray and on a dead hook it flashes to a hair over 3600.
Old Sep 15, 2011 | 09:36 PM
  #26
silverz28camaro's Avatar
If you tow with a small converter it really helps to keep it in 3rd gear instead of letting it shift into OD. I have always been told you will have two issues with 245mm converters and towing.... heat and converter clutch being to small.
If you have a GREAT cooler, deep trans pan(aftermarket with fins) and tune it for lockup in "D" position at part throttle you should do ok for keeping heat down, right?
Also leaving it in D(3rd) will take alot of load off the converter clutch while towing.
the only issue then will be not having overdrive and rpms will be higher...but whos racing while towing boats anyway..
zblee
Nov 11, 2015 12:41 AM
wickedRCSB
Oct 30, 2015 09:45 PM
Miguel199
Oct 16, 2015 08:04 PM
bisqikss
Sep 27, 2015 09:40 PM
sTNT971
Sep 26, 2015 06:27 AM
