Ss3600 and shift kit how many spacers?
I'm putting a ss3600 stall in my 4l60e along with trans go HD-2 shift kit and was wondering how many spacers to use and which size drill bit to use? Thanks
Then IMO do like i said, that is exactly how mine is setup and it shift damn good, nice and quick and not violent on the shift.... Also i have been rocking that setup for about 25-30k, it is still shifting fine at 6800-6900 on a regular basis and it has a ton of track passes on the setup...
I didn't have a stall . . . but I did not use any of the spacers . . .
I drilled the 1-2 shift hole to the second largest, and the rest to the smallest hole
If I did it again . . . I would have them all to the smallest drill bit.
I did use one spacer ring on the servo for the band.
on my old truck i had an HD-2 with all the holes drilled to the smaller setting, a corvette servo, and 1 spacer ring on the servo. with my SS3600 it would shift pretty firm, however it did not chirp the tires on the 1-2. it would do that when i had the TT3000 though.
lycominghunter
Aug 15, 2015 12:26 PM
zaathur151
Jul 6, 2015 10:57 PM
