SS3200 vs. circle d 278mm 3200
Like the title says I'm wanting to know what would be the best converter for my set up. I will be street racing and taking this truck to the track and I'm wanting the best converter for my goals. I have always had yank converters and have heard good things about circle d so I want everyone's opinion.
06 crew cab 5.3L
3.73 gears
29.9 inch tire
Full bolt ons
Tr220 cam ( or custom grind around that size)
Thanks guys
06 crew cab 5.3L
3.73 gears
29.9 inch tire
Full bolt ons
Thanks guys
Resident Retard
If you do street racing and take it to the track i would go with the circled 3C 3600.
Pro Stage I 245mm Truck Torque Converters For GM 4L60 LS
A 9.5" (245mm) converter is going to flash well with the mods mentioned but I think it may be a bit sloppy on the street with the weight of a CC. An 11" (278mm) will be stronger and tighter on the street in a heavy truck but would lack the hit of the 9.5" without a lot of power. FTI makes a 10" and a 10.5" that could be a good compromise if you decide to add power later. I am using one of their 10.5" converters and it is working much better than another brand 9.5" I had before it. Any of the manufactures in this thread would be good choices (I have used two of the three of them) so give them a call and see what they recommend for what you want.
Thanks man. And I met u at xxx before with John u still got the 370whipple combo? And I think I have it figured out. Got a cam spec for my needs and the stall speed I need with it. Thank for all the help now just gotta get my *** to order it all. Gulp
