squeal during shift
Old Aug 5, 2006 | 06:22 PM
regency's Avatar
Default squeal during shift
i think its kinda funny!! but i know its killing the belt. used to i would take off at a stop sign and right before the 1-2 shift i would let off and the belt would squeal, it might still do it. now since i installed the corvette servo and sonnax super hold 4th gear servo, when WOT it will almost bark the 1-2 shift and when it goes 2-3 shift it will squeal the belt. do you recommend investing in some underdrive pulleys or would that make it worse?
Old Aug 5, 2006 | 07:49 PM
Lightbulb
It's normal from what I was told at the dealership. My 05' VHO has done it from day one. The belt squeals right after it shifts from 1-2 and 2-3.
The abrupt slowing of the accessory drives from the sudden shift change is the cause of this. I only get this squeal during WOT shifts.
Jim
Old Aug 5, 2006 | 09:30 PM
Wheatley's Avatar
Truck Sponsor
My Tahoe does it also,especially on the 2-3 shift at WOT,it got worse after I firmed the shifts up also but on well
Old Aug 6, 2006 | 12:22 AM
regency's Avatar
same here on mine. GM needs to make a fix for this, because its ruining my belt. it has alot of slip marks on it. mine has done it since the day i got it to, and so has my buddies vortec max
Old Aug 6, 2006 | 01:13 AM
5.7's Avatar
5.7
yeh me too think its the ulternator pulley but when i went to a slightly smaller belt it stoped doing it. get
Old Aug 6, 2006 | 07:38 AM
FLT's Avatar
FLT
FormerVendor
A shorter belt might be a good solution to add a little more tension. Does anyone make and adjustable tensioner? I would think that it would be a good idea!
Old May 17, 2007 | 06:35 PM
CHEVRACER83's Avatar
Mine Never Did It Before.... But Now That I Installed Teh Corvette Servos, And Sonnax 4th Gear Super Hold Servo.... It Does It On The 1-2 Shift. On A 4.8.... Is It Ok??
Old May 17, 2007 | 08:23 PM
mdwatts11's Avatar
Mine does it..its all stock-right now at least!
Old Nov 4, 2007 | 10:09 PM
VHO 6.0's Avatar
Mine did the same thing until I installed a dayco poly cog belt on it, which is basically a gatorback. Has'nt squealed since.
Old Nov 4, 2007 | 10:12 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Mine will squeel only when I let off right before the shift like that. If I stay in it it will not squeel.
