Spool VS. Posi
Old Aug 5, 2007 | 09:23 PM
usarmyman's Avatar
Default Spool VS. Posi
Doesn't a mini spool and a posi do the same thing? What would be the diffrence, would I get the same advanteges of a posi? Or would a spool make my truck unstretable?
Old Aug 5, 2007 | 10:15 PM
Stoichiometric's Avatar
You don't want a mini spool. The spider gears get replaced by a splined sleeve that couples them together permanently. Look into a detroit tru track or similar.
Old Aug 6, 2007 | 03:33 AM
skyhighsami's Avatar
no title here
Spool means no variation between wheel speed. You go around a curve the inside wheel has to travel less distance. With a spool both wheels will travel the same speed all the time. So around a corner the tire will spin, chirp, or scrub leading to accelerated tire wear and wreck in the rain if you aren't careful. If you like the driveablity of your truck don't do a spool. More hassle than they are worth.
Old Aug 6, 2007 | 09:13 AM
2001si3rr@'s Avatar
Makes daily driving a pain, back wheels want to always goes straight in corners.
Old Aug 6, 2007 | 12:15 PM
dirt track racer 81's Avatar
i gotta full spool in my dirt track race car, which works the same way as a mini spool but takes away the spider gears and carrier..but when you turn it is very hard on tires..in time you will wear out your tires pretty quick
Old Aug 6, 2007 | 12:18 PM
usarmyman's Avatar
Ok, guess I will be going for the Posi or a locker.
Old Aug 6, 2007 | 02:10 PM
rivierakid55's Avatar
a spool will turn your daily driver into a weekend warrior real quick. get a locker or true-trac.
kainzien
Nov 10, 2023 11:37 AM
turbo6c3
Oct 5, 2015 06:11 PM
lsxperformance
Sep 14, 2015 10:53 AM
