spinning is no fun, help.
Old Sep 2, 2011 | 11:25 PM
youngbuck's Avatar
Default spinning is no fun, help.
Was at the track tonight and kept blowing the tires off in 1st , I know the truck is light in the back. I thought about adding a bladder, thoughts on that? I know yall will say get dr but I don't really want to have to deal with that.I have the stock 93 rear end with 3.42s, thinking of adding a new posi unit. It's my dd but does see track time fairly often. What brands should I look at and why? I plan on boost down the road so would like it to hold up to 450-500 to the ground eventually. Thoughts opinions? Mods in sig ...Thanks
Old Sep 2, 2011 | 11:44 PM
Chevy_King1500's Avatar
most guys on here are running the cal-tracs.
-what psi are you running in the tires at the strip?
Old Sep 3, 2011 | 04:12 PM
youngbuck's Avatar
Tires are goodyear eagles, 275/55 r 20 at 41 psi
Old Sep 4, 2011 | 04:16 PM
youngbuck's Avatar
Any thoughts?
Old Sep 4, 2011 | 04:40 PM
ak2007r6's Avatar
I would not add more weight for traction. The improvement if any would not be worth it once moving. I would look into the cal-tracs or something along those lines and check into slicks or drag radials. Just find a cheap or used set of rims to mount them to, makes for a quick change out.
It's not mentioned but I am assuming 2wd right?
Old Sep 4, 2011 | 04:42 PM
BadAssChevy327's Avatar
ya. my thoughts are as follows...
what in your mind tells you you can hook a lq9 with a 4,000 stall in obs with 20 inch street tires?
thats all.
i see you are a z71. if you plan to run in 2wd i have a amazing suspension set up for those years im willing to sell in detail for 30 bucks.. lol jk
Old Sep 4, 2011 | 04:45 PM
phasemaster1's Avatar
41 psi is pretty high. Should be running between 25-30psi
Old Sep 4, 2011 | 04:49 PM
ak2007r6's Avatar
This may be a dumb question but aren't all Z71's 4x4? I don't think I have ever seen a 2wd Z71... it just would make no sense.
Assuming you have 4x4 just flip the switch and launch that way =)
Old Sep 4, 2011 | 04:52 PM
Troponin's Avatar
My thoughts as well.
Old Sep 4, 2011 | 06:07 PM
all z71 are 4wd up untill like 07 or so when the tahoes had a 2wd option and a az71 appearance option.
also unless those tires get a nice bite and let that suspension some what work i dont see a 4,000 stall lq9 hooking
