Some more 4l80e swap questions
Old Nov 14, 2014 | 01:02 PM
aEddin's Avatar
Default Some more 4l80e swap questions
first, im new here, iv creep around the forums for awhile, and finally signed up, a lot of good info and write ups on here.
Any-who, i picked up a junk 2000 OBS 2500, and just so happens it had a freshly rebuilt 4l80e with 12 O'clock bolt hole in it. Opened it up and no film, the filters not even black yet. Anything i should check for to make sure it was done right? Im planning on throwing a trans-go HD2 in it, change fulid (Because most spilled out, fluid was still light pink no smell to it) and calling it a day.
Its going in my 2001 ext. Cab 5.3 with a factory 2 piece. What i cant figure out is do i need to shorten the drive shaft or not? iv found no for sure answer for the two piece.
Old Nov 15, 2014 | 07:59 AM
dirt track racer 81's Avatar
No you can just slide your carrier bearing back and it will fit just fine.
Old Nov 19, 2014 | 03:04 PM
BLKSSLTT's Avatar
formerly turbo4.8 (2014-06-25)
does the 60 and 80 use the same yolk as well?
Old Nov 19, 2014 | 03:12 PM
No you'll have to get the th400 car style yoke and more than likely will have to cut it down.
I also have tubular crossmembers for the swap as well..
Old Nov 19, 2014 | 03:33 PM
N/ALS1's Avatar
I would recommend his crossmember, quality stuff.
chadjcompton
17
Jun 21, 2022 08:47 PM
XL7
May 5, 2022 01:48 PM
lycominghunter
Jul 29, 2015 04:24 PM
alex226
Jul 16, 2015 10:55 AM
lxcoupe
Jul 14, 2015 10:14 PM
